1961 361 electronic ignition conversion
plymouth
Posted 2014-04-13 10:41 PM (#435921)
Subject: 1961 361 electronic ignition conversion
20001001002525
I'm looking to upgrade to electronic ignition. Nothing is wrong with points but my distributor has a little end play and I figure I'd like to upgrade. Does anyone know of an inexpensive, reliable setup?
plymouth
Posted 2014-04-13 10:45 PM (#435922 - in reply to #435921)
Subject: Re: 1961 361 electronic ignition conversion
20001001002525
I should also mention that it is a single point Auttolite distributor
Edited by plymouth 2014-04-13 10:50 PM
Mopar1
Posted 2014-04-14 5:20 AM (#435945 - in reply to #435922)
2000100025
Check Pertronix, or the mopar performance kit.
Posted 2014-04-14 7:43 AM (#435955 - in reply to #435921)
Subject: RE: 1961 361 electronic ignition conversion
Pertronix don't supply a kit for the single point RB distributor, only for the dual point distributor. I used a Bouchillon kit, which requires some simple wiring mods to fit, along with mounting the control unit. I suspect you can buy the same unit cheaper on ebay
http://www.bouchillonperformance.com/distributors
Steve.
Edited by 60 Imp 2014-04-14 7:45 AM
