alignment specs running radials
plymouth
Posted 2014-01-08 9:26 PM (#421115)
Subject: alignment specs running radials
20001001002525
I need specs for front end alignment on my 61 polara. It has power steering and the front end is completely rebuilt. Im running radial tires and using the car daily.
Thanks
Posted 2014-01-09 1:32 AM (#421140 - in reply to #421115)
Subject: Re: alignment specs running radials
50005000200010002525
Cristian, you should use the same specs as I did on my '60 Chrysler - it runs like a dream.
Aim for 2° caster (compromise 1,5°) and 1/4° to 1/2° negative camber.
http://www.forwardlook.net/forums/forums/thread-view.asp?tid=47158&... radial &highlightmode=1#M382348
Below, you'll find the alignment report (sorry in Swedish, but your shop would understand) of what we were able to achieve without the offset bushings for the upper control arms
Edited by wizard 2014-01-09 3:54 AM
Attachments Hjulinstttllningsrapport_Radial_Saratoga.pdf (247KB - 213 downloads)
plymouth
Posted 2014-01-10 10:55 AM (#421313 - in reply to #421115)
20001001002525
Thank you
littlecarl
Posted 2015-05-20 2:47 PM (#478945 - in reply to #421115)
10010010025
I've just put the front end back in on mine. I have manual steering and tried setting it as per factory manual (positive camber, negative caster) and didn't like the way it handled.. Will try this setting that you suggest wizzard. Out of interest how did you measure the castor? I've been using a digital angle gauge across the top and bottom front face of the steering knuckle clost to where the ball joints go in? I couldn't find any other suitable place to measure from.
