Location: Milwaukee Wisconsin | Are there any specail tricks to replacing the neutral safety switch on a powerflite trans..
is there going to be a flood of oil gushing out or other parts misligning when installing the new switch ?
It appears to be a simple item to replace .. just wondering.
Thanks for any details.
john
Edited by dodge59 2013-01-27 10:12 PM
Location: Chestertown, NY ( near Lake George) | You will drain some oil doing this, make sure you lube the seal going back in, don't over tighten. |
