![500](http://forwardlook.net/forums/images/decorations/multiple/500.gif) ![100](http://forwardlook.net/forums/images/decorations/multiple/100.gif) ![100](http://forwardlook.net/forums/images/decorations/multiple/100.gif) ![25](http://forwardlook.net/forums/images/decorations/multiple/25.gif) ![25](http://forwardlook.net/forums/images/decorations/multiple/25.gif) ![25](http://forwardlook.net/forums/images/decorations/multiple/25.gif) Location: Edmonton, Alberta | With the fourth day in a row of 50 degree+ temperatures here, I thought it was time to get a few odds and ends handled on the Fury. Over the winter when we had a brief thaw, I pulled my car's clock and heater control valve and send them off for service. I'm still waiting on the heater control valve's return, but decided that I should get the clock re-installed. When I sent the clock in for repair, I also ordered a bottle of paint suitable for repainting gauge needles. I also thought it was time to investigate a nasty green puddle that had formed underneath the car. I wasn't at all happy to see the puddle underneath the car as over the summer, I'd pulled the rad and had dropped it off at a radiator shop for cleaning and repairs.
Last night, I put a pressure tester on the rad and came out this morning to discover that the leak was coming from a lower rad hose connection off the waterpump that I'd neglected to tighen enough, and that I have an additional small leak from the thermostat housing. I tightened the hose clamp. The t-stat gasket will have to wait until later.
Job two was next. I pulled the cluster and pulled the temperature and fuel gauges. I refinished the needles and re-installed the gauges. I pulled the speedometer, refinished it's needle, and re-installed it. I decided that a few drops of oil on the spedometer's wick might be a good idea, so I did that too. I put the clock back in the car and re-installed the cluster. I set the clock, connected the battery, and tick-tock. I hit the key and made sure I didn't screw anthing else up while I was working on the cluster and everthing seems to work as it shoud. As I type this, I realize I forgot to hook up the speedo cable... a job for next weeked I suppose.
I thought I post a picture of the dash now that it's back in the car. I have a before shot, but it's too big to post here. I'm not that good at resizing!
This job wasn't rocket science, but it did require some patience. I took a lot of photos as I completed the work. If anyone is interested, I can do a how-to article and post it in the technical section of the fourms
Edited by sconut1 2012-03-31 10:07 PM
(PICT0132.JPG)
Attachments ----------------
![](/forums/profile/get-photo.asp?memberid=4118&type=profile&rnd=735) Expert
![1000](http://forwardlook.net/forums/images/decorations/multiple/1000.gif) ![500](http://forwardlook.net/forums/images/decorations/multiple/500.gif) ![100](http://forwardlook.net/forums/images/decorations/multiple/100.gif) ![100](http://forwardlook.net/forums/images/decorations/multiple/100.gif) ![25](http://forwardlook.net/forums/images/decorations/multiple/25.gif) Location: Hay Lakes, Alberta, Canada | Hi Gord,
Wow, the Fury's cluster looks snazzy!. Now, if we can discuss the steering wheel wrap... ![](http://forwardlook.net/forums/images/emoticons/laugh.gif) | |
![500](http://forwardlook.net/forums/images/decorations/multiple/500.gif) ![100](http://forwardlook.net/forums/images/decorations/multiple/100.gif) ![100](http://forwardlook.net/forums/images/decorations/multiple/100.gif) ![25](http://forwardlook.net/forums/images/decorations/multiple/25.gif) ![25](http://forwardlook.net/forums/images/decorations/multiple/25.gif) ![25](http://forwardlook.net/forums/images/decorations/multiple/25.gif) Location: Edmonton, Alberta | Yea, I know. That's gotta go, but I'm a bit chicken to take it off. I don't know what I'm going to find under that and a steering wheel repair job isn't in the budget right now. I blew a good part of this year's car budget on a new dashpad. It should be here in a couple of weeks. Incidently Brad, if you need to do the same for your car, I've got enough paint here to do a dozen cars! Feel free to borrow. | |
