Location: Ballwin, Missouri | Lou, If you use an A518 ( now called a 46RH ) out of a Dodge truck the change over shouldn't be very hard at all. Be sure to get an RH and not an RE. RH uses the old mechanical governor weights. The RE doesn't have governor weights at all and has to have a PCM to control the shift schedule. The RH transmission can be shifted into O.D. and converter lock-up with manual switches on the dash if you want to. Use a trans. from a '95 or older 1/2 ton two wheel drive truck. Whether or not it will bolt directly to your engine, I don't know, but an adapter shouldn't be any big deal.
I'm going to do the same thing to my Coronet but I'm going to use a 5.9 MPI create motor with the PCM and fuel injection. I am also staying with a '95 and older because of OBD II and emission upgrades that happened in'96 and newer vehicles.
Hope this help a little. If you need more help feel free to e-mail me. |
