What's happened?
SavySavoy
Posted 2011-11-21 8:25 PM (#296962)
Subject: What's happened?
1002525
My posts are showing as disabled and when I'm ONLINE it shows I'm OFFLINE. I don't understand what's going on.
61plymy
Posted 2011-11-22 11:23 AM (#297035 - in reply to #296962)
Subject: Re: What's happened?
2000500100100100
You've crossed into another dimension which is a mirror version of this one.
Next time you get out of your FL car, slide out backwards verrrrryy slowly.
Mike
SavySavoy
Posted 2011-11-22 1:23 PM (#297051 - in reply to #296962)
Subject: RE: What's happened?
1002525
Actually we had a computer crash and finally got a new one. Worked on the drag car with my son & his Bride, went drag racing, couple of car shows and worked on my '60 Savoy some. Then back in May I shattered my femur and: had surgery to put it back together, including a rod in it, and trying to get it to heal, get the strength built up, learning to walk again & going to get a 2nd & maybe 3rd opinion to see if I really will have 2 or 3 more operations. It was bad, a week in the hospital and a month in a nursing home. I'm finally out of a wheelchair except when we go to the store.
Rebels-59
Posted 2011-11-22 2:55 PM (#297062 - in reply to #297051)
500050002000500
Click Top Right hand Corner and go to your Control Panel.. It may have your Posts Disabled and User Visibility Disabled.. You can Click both back on and Save,, See if that may be the Problem as you can clearly still Post Messages..
Clive
SavySavoy
Posted 2011-11-22 3:11 PM (#297065 - in reply to #297062)
1002525
Rebels-59 Coronet - 2011-11-22 2:55 PM
Clive
Clive, thank you. I did what you said and it's now fixed, Larry.
Rebels-59
Posted 2011-11-22 5:08 PM (#297075 - in reply to #296962)
500050002000500
Glad i could Help Larry..
Clive.
61plymy
Posted 2011-11-23 12:03 PM (#297182 - in reply to #296962)
2000500100100100
SavySavoy,
Glad to hear you're on the mend and getting it back to gether.
It's tough having to lay around healing. You'll get back to where you were.
Mike
