![](/forums/profile/get-photo.asp?memberid=782&type=profile&rnd=936) Expert 5K+
![5000](http://forwardlook.net/forums/images/decorations/multiple/5000.gif) ![2000](http://forwardlook.net/forums/images/decorations/multiple/2000.gif) ![100](http://forwardlook.net/forums/images/decorations/multiple/100.gif) ![100](http://forwardlook.net/forums/images/decorations/multiple/100.gif) Location: Victoria, BC, on Vancouver Island, Canada | I found this on another site........ so don't reply to me if anyone can help or knows of a hood. - Ian
Hello, my name is Tom Allen. I'm an independent damage appraiser in Central Florida. I'm working to help repair a 1957 Chrysler 300C that had the hood blow up on it. I know these are rare, and I know they are expensive. I'm willing to allow for a fair (or more than fair) price for a hood. If you know someone that has a spare hood, please pass this on. If you have a hood that you are willing to sell, please e-mail me the details and a picture of the hood.
Thank you for any help you can provide.
Tom Allen Sterling Appraisal Service sterlingappraisalsvc@tampabay.rr.com
p.s., the hood looks better than it is. The hood is 'oil canned' and both corners are buckled and twisted.
Edited by imopar380 2010-08-27 1:23 AM
(IMG_8703.jpg)
Attachments ----------------
![](/forums/profile/get-photo.asp?memberid=353&type=profile&rnd=854)
![5000](http://forwardlook.net/forums/images/decorations/multiple/5000.gif) ![5000](http://forwardlook.net/forums/images/decorations/multiple/5000.gif) ![5000](http://forwardlook.net/forums/images/decorations/multiple/5000.gif) ![5000](http://forwardlook.net/forums/images/decorations/multiple/5000.gif) ![2000](http://forwardlook.net/forums/images/decorations/multiple/2000.gif) ![500](http://forwardlook.net/forums/images/decorations/multiple/500.gif) ![25](http://forwardlook.net/forums/images/decorations/multiple/25.gif) Location: Parts Unknown | Yeah, ....... good luck on that.
![](/forums/profile/get-photo.asp?memberid=1117&type=profile&rnd=481) Expert 5K+
![5000](http://forwardlook.net/forums/images/decorations/multiple/5000.gif) ![2000](http://forwardlook.net/forums/images/decorations/multiple/2000.gif) ![500](http://forwardlook.net/forums/images/decorations/multiple/500.gif) ![100](http://forwardlook.net/forums/images/decorations/multiple/100.gif) ![100](http://forwardlook.net/forums/images/decorations/multiple/100.gif) ![100](http://forwardlook.net/forums/images/decorations/multiple/100.gif) Location: Williams California | If a 300 hood cannot be found, a good metal man can take a standard '57 Chrysler hood, and cut the damaged corners from the 300 hood and weld the unstretched ones in. A small bit of solder will still need to be used for smoothing out the splice afterwards.
---John |
![2000](http://forwardlook.net/forums/images/decorations/multiple/2000.gif) ![2000](http://forwardlook.net/forums/images/decorations/multiple/2000.gif) ![25](http://forwardlook.net/forums/images/decorations/multiple/25.gif) ![25](http://forwardlook.net/forums/images/decorations/multiple/25.gif) Location: Connecticut | big m - 2010-08-27 2:09 PM If a 300 hood cannot be found, a good metal man can take a standard '57 Chrysler hood, and cut the damaged corners from the 300 hood and weld the unstretched ones in. A small bit of solder will still need to be used for smoothing out the splice afterwards. ---John Can this be repaired heat shrinking, along with hammer and dollying ? Ron
![](/forums/profile/get-photo.asp?memberid=2333&type=profile&rnd=601) Elite Veteran
![1000](http://forwardlook.net/forums/images/decorations/multiple/1000.gif) ![25](http://forwardlook.net/forums/images/decorations/multiple/25.gif) ![25](http://forwardlook.net/forums/images/decorations/multiple/25.gif) Location: Building incorrect cars since 2000!! | big m - 2010-08-27 2:09 PM
---John
Well from the look of the car it could use a good body man.. is it just me or is this car three shades of white??? |
![](/forums/profile/get-photo.asp?memberid=2543&type=profile&rnd=479) Board Moderator & Exner Expert 10K+
![5000](http://forwardlook.net/forums/images/decorations/multiple/5000.gif) ![5000](http://forwardlook.net/forums/images/decorations/multiple/5000.gif) ![2000](http://forwardlook.net/forums/images/decorations/multiple/2000.gif) ![1000](http://forwardlook.net/forums/images/decorations/multiple/1000.gif) ![25](http://forwardlook.net/forums/images/decorations/multiple/25.gif) ![25](http://forwardlook.net/forums/images/decorations/multiple/25.gif) Location: Southern Sweden - Sturkö island | ronbo97 - 2010-08-27 8:24 PM
I have done some heat shrinking with a soldering tip fixed to the nozzle of a MIG welder - very good result as only heat will be applied to the spot. Yes Ron most probably it can be fixed, but if one pays for the work, it will be cheaper to find a hood in comparison - but, as we all know, those hoods does not grow on trees ![](http://forwardlook.net/forums/images/emoticons/stressed.gif) |
![](/forums/profile/get-photo.asp?memberid=996&type=profile&rnd=710) Exner Expert 19,174 posts. Neil passed away 18 Sep 2015. You will be missed, Neil!
![5000](http://forwardlook.net/forums/images/decorations/multiple/5000.gif) ![5000](http://forwardlook.net/forums/images/decorations/multiple/5000.gif) ![5000](http://forwardlook.net/forums/images/decorations/multiple/5000.gif) ![2000](http://forwardlook.net/forums/images/decorations/multiple/2000.gif) ![2000](http://forwardlook.net/forums/images/decorations/multiple/2000.gif) ![100](http://forwardlook.net/forums/images/decorations/multiple/100.gif) ![25](http://forwardlook.net/forums/images/decorations/multiple/25.gif) Location: bishop, ca | The adjuster is being conscientious in attempting to locate a replacement hood assembly.
Of course the hood can be repaired, but the Ins. Co. needs to confirm the cost/availability to replace it, before
proceeding to Plan B (cost to repair).
Edited by d500neil 2010-08-27 3:07 PM
![](/forums/profile/get-photo.asp?memberid=2145&type=profile&rnd=684) Expert
![1000](http://forwardlook.net/forums/images/decorations/multiple/1000.gif) ![100](http://forwardlook.net/forums/images/decorations/multiple/100.gif) ![100](http://forwardlook.net/forums/images/decorations/multiple/100.gif) ![25](http://forwardlook.net/forums/images/decorations/multiple/25.gif) ![25](http://forwardlook.net/forums/images/decorations/multiple/25.gif) ![25](http://forwardlook.net/forums/images/decorations/multiple/25.gif) Location: Nasco , SWEDEN | Hi Everybody! he could try my friend Bobby! He got parts For 300c.
ewngbbby@aol.com Regards Morgan EXTRA EXTRA READ ALL ABOUT IT! i´ve contacted the guy ![](http://forwardlook.net/forums/images/emoticons/cool.gif)
Edited by mogge65 2010-08-27 3:39 PM
![25](http://forwardlook.net/forums/images/decorations/multiple/25.gif) Location: Lakeland, FL | Hello, I'm the Insurance Guy! Morgan and Ian were nice enough to post this here as well as contact me regarding the thread. Thanks guys. I've sent an e-mail to Morgan's friend Bobby.
I know the cost of these hoods. Anywhere between $750 and $2K, depending on condition. It would probably cost this much to fix this one. I would rather put a hood on the car to repair it simply because it would be the right repair. You can fix anything if you throw enough money at it, but some things should be replaced if they are available. I know '57-'58 hoods are the same and maybe even the '59's. I've found the hinges (from a '58), but could still use the hood. The fenders were also damaged (not bad) and will be repainted. The owner is having the front end redone while the car is apart.
The car IS three shades of white. The car was being repainted little by little. The roof was first, then the hood... . The car is solid and originally from Louisiana. I've seen the barn find pics and the car had nothing but surface rust with some of the trim pulled. The engine was rebuilt and it gave me chills listening to that big Hemi.
I'm a big lover of Chrysler Letter Cars and was briefly a member of the 300 Club about 20 years ago. I've also restored a '71 Plymouth Sport Fury GT. I love the big Mopars. Barrett-Jackson has priced me out of these cars though. Now I have two Studebakers.
Edited by Swifster 2010-08-27 4:45 PM
