Location: Connecticut | What is the correct location for the p/b vacuum canister for a 60 Dart ? Does anyone have a pic of a 60 Dart (318) engine compartment with a power brake setup ? Ron
Edited by ronbo97 2010-06-10 10:39 PM
Location: WHEELING,WV.>>>HOME OF WWVA | under the battery------------------------------------------------------------------------------later
(002.JPG)
(003.JPG)
(vacuum canister 60 dart 001.JPG)
(vacuum canister 60 dart 002.JPG)
Attachments ---------------- 002.JPG (133KB - 228 downloads) 003.JPG (130KB - 222 downloads) vacuum canister 60 dart 001.JPG (104KB - 227 downloads) vacuum canister 60 dart 002.JPG (108KB - 230 downloads)
Location: Connecticut | Hi Chuck - Your engine compartment doesn't exactly look stock. :) I'd like to see pics of a stock 318 setup, including how vacuum canister is installed. I'm working with someone that has a '60 Dart with a 57-9 style booster setup. Did all makes of Chrysler Corp. cars have the same setup for '60 (T-connector for vacuum by booster, canister under battery, etc.) Ron
Location: N. Georgia | Ron, Chuck's setup looks just like the one on my 61 Plymouth with a 318. |
Location: Connecticut | Nile - Do you have a better pic of how the vacuum canister is mounted ? I kinda can't tell from either of his pics. Ron
Location: Victoria, BC, on Vancouver Island, Canada | The vacuum reserve canister in my 60 Chrysler is mounted inside the front fender behind the headlights. Most of the ones I've seen are under the battery. |
Location: Connecticut | imopar380 - 2010-06-11 11:38 PM The vacuum reserve canister in my 60 Chrysler is mounted inside the front fender behind the headlights. Most of the ones I've seen are under the battery. So was this a custom installation, or do Chryslers have it inside the front fender, while all others have under the battery ? Ron
Location: Eastern Iowa | My F is under the battery as is the windsor parts car I have here
Dave S. |
Location: N. Georgia | Mine is under the battery. Although it's hard to see much in the above pics, the hose on mine seems to follow the same route as Chuck's. I would try to get a pic but just had my hip replaced and I'm on a walker right now so I can't get out at the moment. |
Location: WHEELING,WV.>>>HOME OF WWVA | let me get this straight ! because my engine bay is not completely stock , you decline my help with your question , even though you don't know what it is supposed to look like ? what a crock of shiit and if you like tell fearless i said so----------------------------------later |
Location: Connecticut | A little over-sensitive, are we ? Instead of throwing a tantrum, why don't you post a pic of the location of your vacuum tank, which is what I was looking for ? Ron
Location: Connecticut | On the same topic, there is a T-connector at the bellows on the hose that draws vacuum from the intake. Why was this used starting in '60, but not in 56-9 ? How does it function ? Ron
Location: Blythewood, SC | ronbo97 - 2010-06-12 4:37 PM
He did. Actually, two pictures of the tank.
Edited by 57plymouth 2012-02-24 2:05 PM
Location: Connecticut | 57plymouth - 2012-02-24 2:04 PM ronbo97 - 2010-06-12 4:37 PM A little over-sensitive, are we ? Instead of throwing a tantrum, why don't you post a pic of the location of your vacuum tank, which is what I was looking for ? Ron
OK, I'll respond even though this thread is almost two years old.
The tank is obscured and I couldn't figure out from the pics where it was, since only about 5% is visible. No offense meant against Chuck.
Ron |
Location: Blythewood, SC | I didn't look at the date. This thread was referenced elsewhere today. My apologies. |
