Looking for a paddle
55BlueHeron
Posted 2010-04-27 4:31 PM (#220573)
Subject: Looking for a paddle
50025
I'm up a creek - thus the title.
This isn't about my Chrysler but rather about the ex-step-sibling (the product of Chrysler's ex-spouse, Mercedes).
I disassembled the suspension on one side of the Mercedes to do the kingpin. Using my tools I measured the old kingpin and the old bushing and learned that the pin is larger than the bushing. I decided that faulty measuring was more likely than an exception to known physics, and thus my issue.
1. I can reassemble the whole thing and pay someone an estimated $1800 to take it apart again and do the work.
2. I can buy new quality micrometers that I will use once in my life.
3. I can find someone willing to ream press and ream the bushings.
The tolerances are quite tight, with a clearance between the pin and bushing of 0.005 mm (0.0002 inch).
I'm willing to barter or pay. I just paid a little over $200 for a Chadwick and Trefethen adjustable reamer and guide (size F which is used on many classic car kingpins).
safetymike77
Posted 2010-04-27 7:07 PM (#220590 - in reply to #220573)
Subject: Re: Looking for a paddle
2000200050025
They don't liquid nitrogen the pin do they? I would think maybe the bushing, but not the pin....
Posted 2010-04-27 8:20 PM (#220603 - in reply to #220590)
5000500050005000200050025
.... and here I thought someone was going to get a spanking !
55BlueHeron
Posted 2010-04-27 9:55 PM (#220625 - in reply to #220573)
50025
I'm the one needing spanked for starting this nightmare!
With that clearance the pin and bushing go together firmly, or as someone said it slides in but doesn't drop in. I don't need a Mercedes mechanic. I just someone accustomed to kingpins and tolerances, and willing to put those two together.
Another option is to replace a broken part I found, check for other broken parts, and put it back together with a loose kingpin. The kingpin won't break, but handling and ride will be compromised.
Posted 2010-04-27 10:27 PM (#220638 - in reply to #220625)
Mercedes = Spanking
