Hi guys, I have never removed a dash from a pre 60's car and need to pull mine to replace all of the wiring (57 Suburban, 301 poly/2 speed auto trans, non AC, total stripper) .
I'd like to remove it as complete as possible without removing anymore items that required to get it out of the car intact. Do any of you have a procedure list? It would be very helpful. I have already removed the inside windshield surround, the top screws under the windshield glass, and the two larger lower bolts that cradle the ends. The dash is loose but won't come out so some mining underneath for hidden attaching bolts, cables, and such is in order.
Thanks! |
Location: Southern California | I've done this task, theres no real order just be patient fish through everything top and underneath, take pictures of stuff everything where needed to reassemble properly especially where the wires and plugs go into the guage cluster. If I remember correctly you will have to undo the bolts underneath the steering wheel as well and push down the colum alittle so you can free the dash, also you may have to take out the front bench seat as well to get it out, the main screws to remove are along the top end of the dash the two side bolts and the two at the base of the steering wheel and your good once you remove all wires and pushbutton tranny box from underneath, hope this helps good luck |
Location: Southern California | oh one more thing you need to remove the radio fisrt as it is attached underneath and to the fire wall so it will need to be pulled first to remove the dash too |
| I already pulled the steering column bolts (had to grind a custom socket just to reach the bolts, narrow holes!) and the front seat. Have'nt tackled the radio yet. Seems like most of the dash knobs will need to come off to free up the harnesses that attach to them as well as the E-brake handle and some center straps that hold up the center underneath
Edited by Scott Smith Harms 2009-06-10 7:38 PM
Ok, I have the dash all but out now. Last question
LAST item holding the dash in the car is the push button cable. What end is easier to remove, at the buttons or at the trans? What's the procedure?
Thanks! |
Location: Southern California | Its easier at the buttons, its a little bit of a task but better so you do not disconnect from the trans. first remove the buttons by removing the face plate then with a flashlight and this is why I mean you will need to take the front bench seat out so you can lay comfortably on the floor to get under tha dash so you can work. Anyhow get under th dash and if I remember correctly there will be 3 or 4 small nuts or screws holding the push button box to the dash from behind the dash carefully remove these and you can pull the push button box down away from the dash and your home free |
Location: Wake Forest, NC | Be aware its heavy, at least the 59 was especially if you leave the gauge clusters in. I was by myself and held the lose end with a jack stand while I removed the last bolt. |
Location: Auckland, New Zealand. | There's always more than one way to skin a cat of course, but I found it easier to disconnect the trans cable at the trans end rather than trying to release it at the dash end. That's just me though, I hate working upside down under a dash. And you shouldn't have to remove the switches to remove the dash. Leave them intact to make it easier to see how the wires are routed to them. I would love to see some pics of all this if you have taken any. I made a very simple dash rotisserie for mine, it made it so much easier to spin it over single handed to work on the back without damaging anything on the front. Just 2 shelf brackets, some angle aluminum and some timber.
Glenn.
Edited by FURY 2009-06-11 6:04 PM
(Dashpad-Rotisserie#4-16-01-02.jpg)
Attachments ---------------- Dashpad-Rotisserie#4-16-01-02.jpg (102KB - 518 downloads)
A dash rotisserie? Sounds great !!!!!!!
Do you have any pictures of your rotisserie?
Got a plan you can share?
A list of material?
I am pretty sure a lot of member would be interest in such information.
Thanks.
| Well I got it out, I went with the remove the shift pod method, I feel like a contortionist after that one! Should be interesting re-installing it as well.
So, after I got it out I discovered some broken dash vents....bummer, anyone have any spares laying around?
I need to send my wiper motor out for a rebuild while it's exposed and I plan to pull the windshield as well to address any hidden issues, may as well now that the dash is out.
Thanks for all the help guys!
(Dash vents.jpg)
Attachments ---------------- Dash vents.jpg (20KB - 222 downloads)
Location: Auckland, New Zealand. | No I'm afraid I don't have any more pictures or plans. The dash is in the car now and the frame (rottiserie) is demounted and stored in bits. I made as much of it as I could out of aluminum because it is cheap and light but strong enough to do the job. The base was some flat timber so that it was braced and I could slide it out from under my pool table where I had my dash stored, with ease, single handed. The ends pivoted about a large bolt so that I could rotate the dash 360 degrees single handed without damaging my restored paint. The ends were attached to the dash in 2 positions-where the dash attaches to the A pillar of the car when installed. It took probably 3 hours to build, and paid for itself a hundred times over!
Glenn.
catman - 2009-06-13 1:25 AM
Fury,
A list of material?
Thanks.
:cool: |
Location: Washington, PA | Can either of you guys get me a close up picture of the parking brake light on your plymouth? I am trying to determine if it is the same as my Dodge. My lense is melted because some one put a hot bulb in it at some point and I am trying to come up with a new one. The more model years I know fit the better chance I have. |
Location: Invermere B.C. Canada - Rocky Mountains | eScore - 2017-04-06 11:11 AM Can either of you guys get me a close up picture of the parking brake light on your plymouth?
Sorry, don't have the info you need. Someone might come along,........... but you are posting to a 8 year old thread, I think you would have better luck posting a new post question in the appropriate
location. |
Location: Washington, PA | I am about to do that, but I think I may have finally gotten one located. Thank you. |
Location: Auckland, New Zealand. | eScore - 2017-04-07 5:11 AM
Location: Auckland, New Zealand. | Photos attached of the handbrake warning light on my 57 Fury (on and off), and also of my buddy John Parker's 58 Fury.
Glenn.
(Handbrake light GB#2-small.jpg)
(Handbrake light GB-small.jpg)
(Handbrake light,58Fury-Parker.jpg)
Attachments ---------------- Handbrake light GB#2-small.jpg (205KB - 196 downloads) Handbrake light GB-small.jpg (217KB - 180 downloads) Handbrake light,58Fury-Parker.jpg (36KB - 182 downloads)
