Location: Williams California | Late '50's GM wagons, late fifties to early sixties FORD and Mercury wagons, early to mid sixties International travelalls and possibly others used nearly identical stripping, if you can find some that is not brittle. If too short, you can seam them together, and once installed the seam will be quite hard to distinguish.
If you find these in a salvage yard, be easy on them, as they will be somewhat brittle in most cases. ---John |
