Location: Buffalo, NY | Does anyone know where I can get a spin on oil filter adapter for a poly 318? | |
| This was a recent post, check the thread about spin on filter adapters under this heading your in right now; the adapter is no problem at all, just take one off a newer style 318. The bigger issue is the bypass valve in the block, make certain you correct that as well or you'll have unfiltered oil in your engine: this is explained also in the same thread. | |
