Heavy Power Steering Leak
A1gio2
Posted 2023-10-16 9:57 AM (#632353)
Subject: Heavy Power Steering Leak
I've developed a heavy power steering leak in my '55 Chrysler.
I'm brining the car to a new mechanic that has a good reputation with classics. I want to do my homework in advance of what might be the issue/culprit.
Is there something that's common to leak that he can likely fix without a rebuild or having to special order parts? The leak is heavy enough that it drained the PS bowl twice.
Shep
Posted 2023-10-16 10:54 AM (#632355 - in reply to #632353)
Subject: Re: Heavy Power Steering Leak
20001000100100100100
Can't answer without knowing where the leak is, right?
ronbo97
Posted 2023-10-16 12:05 PM (#632357 - in reply to #632353)
Subject: RE: Heavy Power Steering Leak
2000200025
Is it leaking from the reservoir onto the valve cover ?
Ron
Posted 2023-10-16 1:09 PM (#632359 - in reply to #632353)
20001000500100100252525
If your pump has the top-mounted reservoir, there are "O" rings between the reservoir and the pump body. Most likely a common size that is readily available.
ronbo97
Posted 2023-10-16 3:19 PM (#632363 - in reply to #632359)
2000200025
57chizler - 2023-10-16 1:09 PM If your pump has the top-mounted reservoir, there are "O" rings between the reservoir and the pump body. Most likely a common size that is readily available.
Chiz - There are O-rings, but there is an additional seal that I wasn't able to find. I tried to have it custom made, but it didn't work. I ended up swapping to a different pump, and so far, so good. Note: This is the 55-6 pump attached to the rear of the generator.
Ron
Posted 2023-10-19 2:45 AM (#632400 - in reply to #632353)
5000
yeah wtf mine leaks also.. its the thompson... ive tried 2 new seals and some sealant... arg
Posted 2023-10-20 2:13 AM (#632409 - in reply to #632353)
500020002000500100100100100
If your PS pump is a Thompson, the seal PN is 1408 732 and there are several modern equivalents, e.g. the National Seal 6835S.
If I am wrong and your PS pump is an Eaton, I can repeat the same process and find the PS pump seal for it. Just let me know.
This is the Rock Auto search results for the 1408 732 seal:
https://www.rockauto.com/en/partsearch/?partnum=1408732+seal
Edited by 56D500boy 2023-10-20 2:15 AM
(PointerToSealSection19_54_29For1672697PSPump.jpg)
(SealPNFor1672697PSPump_1408732.jpg)
(ChasingThe1408732SealAtRockAuto.jpg)
(DetailsOnTheNationalSeal6835S_Equivalent totheOE1408732.jpg)
Attachments PointerToSealSection19_54_29For1672697PSPump.jpg (147KB - 41 downloads)
Attachments SealPNFor1672697PSPump_1408732.jpg (149KB - 42 downloads)
Attachments ChasingThe1408732SealAtRockAuto.jpg (142KB - 49 downloads)
Attachments DetailsOnTheNationalSeal6835S_Equivalent totheOE1408732.jpg (141KB - 43 downloads)
Posted 2023-10-21 8:32 PM (#632431 - in reply to #632409)
*IF* needs be the 1639 734 OEM seal crosses to a modern SKF 5046 seal.
Just sayin'
(SealPN1639734ToSKF5046.jpg)
Attachments SealPN1639734ToSKF5046.jpg (147KB - 39 downloads)
