1957 Dodge Leaf Springs
Moderators: Lancer Mike
   Forward Look Local Regions -> Rocky Mountain RegionMessage format
wheelcover
Posted 2022-05-12 10:06 AM (#621417)
Subject: 1957 Dodge Leaf Springs
I’ve got a broken top leaf spring on my 1957 Dodge and would like to replace that one, or ideally both top leaves on each side (two from the same car that are in good useable shape). I’m in Laramie WY. I’ve got Forward Look parts cars, but nothing that’s a match for that spring.
Posted 2022-05-12 5:35 PM (#621429 - in reply to #621417)
Subject: Re: 1957 Dodge Leaf Springs
50001000500
https://www.eatondetroitspring.com/db/es-partsinquiry2.php?syear=195...
dy=2+DR+Lancer+Hardtop+Coupe&seng=V8+5.3L+-+325cid
Leaf Springs Order EATON No. Qualifier Width Lvs Rate P/V Price Wt.
Front Leaf springs are not used on this vehicle
Rear
Stock Ride Height
ML395 Heavy Duty 2.500 6 125 2 $ 335.00/ea 33
Stock Ride Height
ML799 Standard Duty 2.500 5 95 2 $ 335.00/ea 28
Note: On orders for non-stock ride height, there is an upcharge per pair of leaf springs, applied on the order.
Install Kits Order EATON No. Installation Kit Description P/V Price Wt.
Front Install Kit - Call for information.
Rear IKCC1051 *Notes 1 $ 99.00/ea 9
Shocks Order EATON No. Shock Absorber Description P/V Price Wt.
Front NO FRONT SHOCK * NO FRONT SHOCKS AVAILABLE 0 CALL 0
Rear NO REAR SHOCK * NO REAR SHOCKS AVAILABLE 0 CALL 0
Other Prods Order EATON No. Other Product Description P/V Price Wt.
Other Products are not used on this vehicle
=Product Notes *=Normal Stock item.
Modified springs may not be stocked and may be custom made which are not eligible to return, CALL for price
Checkout:
Country to ship to:
United States
Enter Postal Code:
Postal
(Shows products & shipping)
Posted 2022-05-12 5:39 PM (#621430 - in reply to #621417)
50001000500
No Leaves but hardware: https://www.springsnthings.com/leaf-spring-hardware.htm
