Location: upstate new york | Does anyone have a good source for OEM AC rebuild? Mine is original and hasn't worked in a least 40 years but i have a couple belts spinning it every time I take the car out. I know it weighs a ton so shipping might be an issue, but if there is someone that specializes in old mopar AC units, id like to hear about them.
Thanks,
billy |
Location: NorCal | I doubt if you'll find anybody who does a complete system rebuild..you'd be better off dealing with the components individually.
If it hasn't worked in 40 years, has anybody tried simply leak testing and charging the system with refrigerant? Even the perfect original systems leaked a little. Common sources of leaks in aged systems are the compressor seal and the rubber hoses, both of which can be replaced. |
Location: upstate new york | Thanks John....I'll give what you suggested a try.
billy |
